Atlantic British Selling 4.6 Tophat lined motors
Old Jul 22, 2014 | 12:58 AM
  #31
GROVERDISCO's Avatar
I had liners installed in my 4.0 and the guy that did it said that the liners I had him install would outlast about 5 sets of rings and pistons. I had him instal Darton sleeves and he said they are hard as hell!! All I can say is if they install Dartons in their engines the liner should be just fine. I hope this all works out for you.
Old Jul 22, 2014 | 05:27 AM
  #32
jkid's Avatar
Originally Posted by TRIARII
more info would be great. Some pictures of the shop? I wonder where they are getting their used engines.
I may be replacing my head gaskets again soon in which case I'll be visiting him and I can get more details. He only showed me around briefly when I was in there before but he was pretty enthusiastic about showing me what he was doing.
Old Jul 22, 2014 | 07:30 AM
  #33
drowssap's Avatar
have you done any test on the engine?
what exactly is wrong that has you saying the motor is junk?
has a compression test been done?
how about a leak down leak-down test?
oil on top of a piston could be a bad valve guide or seal?
none of the above tests require any disassemble
and should be done by your mechanic before you go any further.
jmo
Old Jul 22, 2014 | 02:47 PM
  #34
Peter_N's Avatar
5th Gear
jmo
Here is the full recap:
Driving, I noticed that I was missing some power.
Some days later, check engine light came on throwing a Cylinder 5 misfire code. I pulled the plug on that cylinder and it was fine. I held out hope that it was maybe the wire but as you probably know it's not easy to pull wires from the coils on these trucks so I took it in.
My mechanic initially thought there was gas in the cylinder which had him thinking it was a valve issue (spring, seal, whatever)...on further inspection he realized there was oil in there. Cylinder 5 failed a compression test miserably. Yes he did a block test too. Not burning coolant thankfully. Taking the valve cover off he couldn't see anything wrong with the valves on that cylinder. Again, I'm not a mechanic but my mechanic is. I trust him 100%.
So here we are.
[edited to fix some grammar and mention the joy of the coil pack placement]
Old Jul 22, 2014 | 03:03 PM
  #35
drowssap's Avatar
Cylinder 5 failed a compression test miserably. that's the part I missed I don't dough your mechanic just looking for easy stuff. maybe you will be somewhat lucky and he may find something if he pulls the head.
i
Old Jul 23, 2014 | 01:08 AM
  #36
Peter_N's Avatar
5th Gear
i
I totally appreciate you trying to be helpful. I need all the help I can get, trust me.
Old Aug 8, 2018 | 12:17 AM
  #37
Jason_B's Avatar
Super old thread, but any update here? I am looking to get an AB engine soon.
Old Aug 8, 2018 | 10:29 AM
  #38
mark d's Avatar
Default Super happy
i have been very happy with my AB engine. They are local for me and I bought my rings through them when I had the machine work done.
Old Aug 8, 2018 | 11:19 AM
  #39
Sixpack577's Avatar
I would be looking at ACEngineer's thread on his LS3 conversion kit. The kit + a used or rebuilt LS3 will be cheaper, and the GM engine is so much better than the LR engine.
Mark G
Aug 31, 2020 01:44 AM
Ducatiryan
Jun 10, 2017 01:39 PM
slammin_LWB
Nov 23, 2016 11:31 AM
amanzi
Aug 24, 2014 09:09 AM
DooDer
Jan 12, 2010 10:46 PM
