Auto leveling suspension.
Old Feb 28, 2005 | 01:51 PM
PabloM's Avatar
Default Auto leveling suspension.
Hey, has anyone had to replace the compresor and the air suspension on the back of their Doscovery II series?. I have some frineds who had to and weren't very happy with the bill for the dealership. Another option that I heard is to take out the leveling system and put on the Old Man Emu suspensio. Any comments will be greatly appreciated.
Cheers!!
Old Mar 2, 2005 | 03:36 AM
Bene's Avatar
Default RE: Auto leveling suspension.
from what i hear, that last option is the most popular.
best of luck
Old Mar 2, 2005 | 01:43 PM
PabloM's Avatar
Thanks Bene!!
Old May 31, 2012 | 10:42 AM
drewhelmax's Avatar
hi new to forum, boy they said disco were expensive to maintain, my latest fault, fitted new rear suspension compresor and cant get it to energise the solenoids to lift the rear,or actually run compressor. do i need to put on diagnostic or what .
Old May 31, 2012 | 10:50 AM
drowssap's Avatar
lets hear it from the beginning, when did you buy it, was it like that? did you come out and find one side down, both side draggings, when did it last work?
Old May 31, 2012 | 11:10 AM
If you want some help with this, send me your number and I'll walk you thru what to do, before you buy more parts you may not need.
Old May 31, 2012 | 02:44 PM
oilspotLR's Avatar
There are a lot of parts guys on the forum that sell parts a lot cheaper than the dealer. I would recommend calling them before you run to the dealer. Somethings you should get new, others if slightly used won't make a difference.
Old May 31, 2012 | 07:07 PM
jljde's Avatar
I got mine replaced with springs.
Old Sep 4, 2012 | 12:47 PM
rondiff's Avatar
7th Gear
Default Self leveling system goes down on both sides
I have a Discovery 2003 HSE with self leveling system. The system will stay up overnight and just sat for 7 days without going down. Therefore does not seem to have leaks. However, it intermittently will go down--it seems on especially bumpy roads. Both sides go down. It will pump up manually after manually letting it down. Any ideas?
Old Sep 4, 2012 | 02:13 PM
When it goes down, does it go down equally or more so on one side then the other, how many miles on your truck and have the bags ever been replaced?
