Automatic Transmission Filter Kit - Autozone $14.99?
With the great info here and on the Rave CD (which I would not know about if not from here) I am going to change my Transmission Fluid and filter.
I have a question on the filter - It seams that there is a big difference on the price. Autozone has a filter kit (with only one o-ring) for 14.99, While British Pacific has a kit for $50 and then the dealer is about 120.
I would normally go for the middle of the road price wise or if it was performance go all out.
Should I go for the 14.99 Autozone?
JC in AZ
2001 Discovery II with 109,000 miles. Not sure when the fluid was last changed owned for less than a year.
I recently changed spark plugs and wires. Magnacore 8mm that I overpaid for since I didnt search the threads for the cheapest place and Platinum +4 plugs.
JC in AZ
Part Number T726
The Part Number is T726, if you search for the part number on their site you will find it. The picture shows the gasket and also one o-ring. Thanks for the feedback. I have not changed a transmission filter before so I do not know what it is made of, so I wanted to get some feedback from here, espcecially since so many aftermarket ones are 50 from online to BAP.
Thanks again. JC in AZ
have not looked at fluid yet
DiscoMike,
I have not looked at the fluid yet. I plan for this to be a Sat morning complete job, so I have not drained it.
The main reason I asked is I didnt know if this filter is just metal type or what. I spend the extra for oil filters but didnt know if it would make a differenct here. At the price may just change it every time change the fluid. I just dont want leaks or problems of course.
I am searching the forums for the best ATF to use I looked at what you mentioned in your 60K service thread. I am also looking for what Spike555 uses. I know all the good names just havent picked one yet. I think once I pick a brand I will go with it for all fluids. I am reluctant to switch to Royal Purple because I have motor oil leaks that need addressed (for sure valve covers and maybe heads) and assume they will be worse with it? May go with all Valvoline Synth. Red Line is carried at Checker/Orielly but not all fluids in stock.
Thanks again,
JC in AZ
Thanks again,
JC in AZ
DiscoMike,
Thanks again,
JC in AZ
Thanks again,
JC in AZ
I flushed out my old fluid and use Red Line D4 ATF. I also use their gear oil and motor oil (good for flat tappet engines). 2004 Disco.
