AUX channel for originale Alpine head unit
Hello everyone,
Does anybody know if it's possible to acces the AUX channel on an Alpine stock head unit without an extra module or converter? What I want is an USB input somewhere in the dash or glove compartement so that I'm able to connect an iPhone or iPod. What are my best options? It's for a D2 year 2002.
I'm from Holland so excuse my English..
Thanks in advance.
Thanks in advance.
there is an online company that will add an extra audio input to your head unit for like $125.00, shouldnt be hard to find one office in the us and one in the uk i believe.
this is a complete stereo
http://www.ebay.com/itm/01-02-Land-R...3D151306186307
here is the company i was thinking of :http://www.gb4x4radios.com/
Thanks for all the answers:
I really would love to keep the car original with this unit.
I've used these adapters (not usb but directly for iPod) before on blaupunkt/grundig radio's, the blue connector is the same as the one for this unit. But on the radio's I had before I knew how to switch the unit to aux without a module. I was wondering if someone knew how to switch it to AUX, or isn't it possible without an expensive module?
Maybe these stereo's don't have that AUX function, unfortanatly I haven't got the user manual so I can't look it up.
Will this one plug in under the passenger seat where the cd player is?
ROVER LANDROVER 99-05 Auxiliary 3.5mm Car Adapter
Thanks
Thanks
Hello everyone,
There is no AUX channel on the 2002 Alpine stock head. An auxiliar audio signal input can be implemented, either with a switching jack to share an audio path or by sacrificing an audio path as AM or cassette that you do not care to use any more.
USB means 'universal serial bus'. That is not an audio signal. Wrong terminology for what you want.
To implement the addition of an external audio (AUX) input, you need very fine soldering skills to do some electronic surgery.
Open the top stereo lid, and locate IC202 (TEA6320) on its main board. It is a 32 pin surface mount integrated circuit. If I remember well, it is under the cassette player mechanism assembly that will need removal for access.
Pins 15 and 18 are cassette left & right. Pins 11 and 22 are AM left & right.
Choose what you want to sacrifice to obtain Auxiliar input.
Critical ----> Lift by desoldering and prying up a millimetre the set of pins of choice, no mistakes allowed. The pins should not contact the board pads or anything else, just hover raised.
Solder a 1 microfarad capacitor in series to each lifted pin. Better short leads.
THOSE are your auxiliar inputs feedpoints.
Solder wires there for an external audio jack, or to a frontal mounted audio jack. stereo 3.5mm is better.
If you chose cassette, insert an endless cassette. Pulsing "Tape" enables audio from your external player.
If you chose AM, pulsing "AM" button enables audio from your external player.
(L) IC pin----capacitor----------------------------------------------------------aux jack (L)
(R) IC pin----capacitor---------------------------------------------------------aux jack (R)
Any grond point -----------------------------------------------------------------aux jack common
Route with slack and secure (better hot glue) the wire safely away from mechanisms to either the outside or somewhere on the front panel. Plug your music player there.
Example of one lifted pin :
----> https://hifiduino.files.wordpress.co...pg?w=595&h=353
Discard (cut off) the male end to use its wiring soldered to the remaining capacitors leads :
----> http://ecx.images-amazon.com/images/...GL._SY355_.jpg
or panel mount :
----> http://www.summitsource.com/images/products/COS535.jpg
Capacitors may look like :
----> http://p.globalsources.com/IMAGES/PD...Capacitors.jpg
The following 3 users liked this post by Externet:
An adapter like that would be nice, when I have the car I'll look for the cable. I know that no cd-changer is fitted.
@Externet: Wow thanks for your detailed DIY.. Sorry for the confusion, that is yet another problem- What I originally wanted was a connector directly for the iPod and iPhone, only one device has the original big connector and the other the new smal lightning connector. An usb port is not analog idd, it would be ideal because I want to charge and play music at the same time, and be able to use both of them. To make things more complicated
I'm not used to that fine soldering, but is sounds pretty straightforward when you explain it. I'm going too think about, I now at least know the unit doesn't have a direct AUX function so it rules out my original plan to use a simple cable like I showed, and play music and charge at the same time..
I could always make something out of such a cable if I have the input signal on the unit, or find a module for it that has a usb port built in and pay a bit more..
Thanks so far everybody
Today I've had a chance to look at the car and made some photo's.
I think I'll go for this Land Rover AUX adapter lead Discovery Range Rover 3.5mm jack iPod MP3 CTVLRX002 | eBay and solder a cable like I showed in my 2nd post to RCA for it.
And then use an adapter for the iPhone like this APPLE 30 PIN TO 8 PIN LIGHTNING ADAPTER CONVERTER For iPhone 4 5 5S 6 iPad iPod | eBay. It should work, in theory.. And less chance for me to mess up the original head unit.
