Average life span of new or rebuilt motors
I did new coils, plugs, wires, oem cooling hoses, oem 180 thermostat, Nissens radiator, coolant reservoir with cap, new oem flexplate, acc belt, belt tensioner, idler pulleys, motor mounts, crank position sensor, coolant temp sensors, etc. The Turner long block will ship with a new water pump, front cover, and all gaskets and cam lube. You will need new exhaust gaskets and studs after the manifolds. You should also do an HD fan clutch and new fan blade as well. Mine were less than a year old, so they were like new. If I had it to do over, I'd do a new starter at the same time. Remanufactured starters run $100. New front O2 sensors would be a good idea as well. Follow the break in procedures carefully to protect the new cam and seat the piston rings. Do it once and do it right was/is my motto. Good luck!
Jason_B (06-26-2018)
Any updates or shared wisdom for someone looking to do the Turner engine replacement? Thanks.
I read and here great things about Turner.
But, for the money, I'de rather spend $10k to Trailhead or Lucky8, and get a Chevy LS conversion. Turn key install, and retains all stock features like traction control.
The following 3 users liked this post by Tomzsix:
Same here. Did Turner long block with upgraded cams and everything is running smooth.
Initially had some high temps but switched to inline mod and they came down quite a bit. Still slightly high temps when it is 100f+ and I need to drive up a mountain.
Idle is a little bumpy as well. Not sure if this is the upgraded cam or if I can resolve this. Working slowly on new plugs, wires and coil packs and also finding any exhaust leaks.
All in all, the engine is running great. Probably have about 15k miles on it over 2 years.
I would consider a turner top hat liner block for 1750 GBP, do you own bearings and piston rings etc. Probably come in under 3k USD total
https://www.turnerengineering.co.uk/...ou-c2x20634976
