Awseome Gadget Mounting System
Old Jun 10, 2021 | 07:40 PM
TimInNova's Avatar
Default Awseome Gadget Mounting System
I just wanted to share this, as I'm very happy with the results. I installed the YakAttack might mount and a bunch of Ram Mount stuff and finally got the top of my dash organized. What's cool is I can adjust and rearrange things to my hearts desire. I hope this inspires someone!
Parts:
Amazon Amazon
Amazon Amazon
Amazon Amazon
Amazon Amazon
Old Jun 10, 2021 | 07:47 PM
whowa004's Avatar
fantastic! I've been thinking of something like this but haven't had time to look into it. Thank you! I have a ram suction mount for my ipad mini but it's not solid over night, not a big deal but it's kind of annoying when it falls randomly esp if there's a temp swing while driving.
Old Jun 11, 2021 | 02:00 AM
acg's Avatar
acg
Great idea! They also have the longer 12" track version that I am thinking of trying out.
Old Jun 11, 2021 | 06:45 AM
keninnc's Avatar
Nice.....I like the idea if you want to un-install it a new rubber mat piece makes the dash look factory and will cover up the holes.
What are the screws holding on to. Is the underside of the dash have something substantial for the screws to get a good grip? or Did you remove the stereo and there are nuts underneath securing it down?
Old Jun 11, 2021 | 06:49 AM
TimInNova's Avatar
I used the screws it came with combined with a medium layer of Clear Gorilla Glue. The Glue really helps the strength, and I can tell you it will come off cleanly with no damage to the dash if you ever decide to take it off. I know this as I had used this glue before to hold down a different mount in the same spot. A bit of prying with a trim tool and it came off clean.
Old Jun 11, 2021 | 07:19 AM
logan_gibson's Avatar
I've got a similar setup, but bolted through the dash to a metal plate. Just have to remove the radio to get to the plate.
After just using screws, some of them cracked the plastic under the dash bouncing around.
hrhoward
Jun 5, 2021 04:31 PM
Theshire4x4
ROAMING WITH FRIENDS
Feb 11, 2018 04:07 AM
ls1morethanyou
Jun 27, 2014 04:33 PM
SuperSport
Apr 17, 2014 08:37 PM
chasej318
Sep 21, 2012 03:45 PM
