Back door leak? Resolved
Old Apr 11, 2018 | 04:07 AM
TaylorCadence's Avatar
Default Back door leak? Resolved
Been having massive amounts of water seeping through my back door. Previous owner used rolled foam weather stripping but it’s been deteriorating so I ripped it out nd put a more legit gasket. It fits perfectly and so far, no leaks! Got it at Ace Hardware. I’m sure it comes in diff colors but browns actually kind of nice. Cost me $8. See pics:
Old Apr 11, 2018 | 05:45 AM
shanechevelle's Avatar
If you would have asked, one of us could have sent you the correct factory piece.
Old Apr 11, 2018 | 05:14 PM
Didn’t think there was one on the door side. What’s the part?
Old Apr 12, 2018 | 03:14 AM
The Deputy's Avatar
There isn't one on the door, correct. I've been thinking about adding a seal like you did, since my door is slightly tweaked, outward, at the top and new inner seal will not fill that gap.
Brian.
Old Apr 12, 2018 | 04:01 AM
LR03NJ's Avatar
Brian.
Brian,
you can insert a round grey foam sealer between the rubber to make it thicker again from home depot. They come in different diameters. It will be tucked inside the factory weather seal and it is not visible. Cheers
Old Apr 12, 2018 | 04:27 AM
Various owners have addressed this issue multiple different ways, I just found what worked for me. Cheap quick-fix solution. My upper seal is fine too and I think I also have a tweaked door (only leaks bad in right corner).
What helps too is the latch is on a slider, you can unbolt it and move it inward to achieve a tighter fit.
Old Apr 12, 2018 | 04:31 AM
Originally Posted by LR03NJ
Brian,
havnt heard of this. Is it round in diameter?
Old Apr 12, 2018 | 06:16 AM
LR03NJ's Avatar
This is the one I used to reseal the rubber strips. They vary in sizes so you can just insert the foam inside the rubber so it wont be visible from outside.
Old Apr 12, 2018 | 08:04 AM
The Deputy's Avatar
Good info, Gerry...thank you.
Brian.
Old Apr 12, 2018 | 10:34 AM
Dave03S's Avatar
What diameter is the Poly Foam caulk sealer in the pic?
