Is this bad?
Old 07-23-2014 | 09:44 PM
zski128's Avatar
Originally Posted by james.martin1
Thanks for the tips guys, it was the tires causing the problems, or atleast most of them. I had my tires balanced after work today and that seems to have fixed the problem, or at least made it good enough for now. All of the tires were badly off balance, and I suspect this was caused by the uneven wear on the tires. I have done a little research and it sounds like cupping is usually caused by bad shocks. Do you think this might be the root of my problems?
I have been thinking of a lift kit but if I raise the truck 2" on top of removing all of the sag in the suspension, and adding larger tires I won't be able to fit in my garage anymore. What are the best options for stock height replacement suspension?
Cupping could be from bad shocks and thats easy to test. Did you check your alignment? The camber and toe was off which caused the cupping in my case.
dparham
04-22-2013 04:03 PM
cobbcj7
04-20-2013 06:45 AM
starcraft1
11-13-2011 08:14 PM
oljohnboy
09-14-2009 03:01 PM
Bene
ROAMING WITH FRIENDS
05-11-2005 04:33 AM
Quick Reply: Is this bad?
