Bad audio quality. Need help diagnosing.
Old Mar 28, 2014 | 12:05 AM
  #31
Echoman's Avatar
Originally Posted by JohnKimble
Let me know what your parts will be and when you plan on doing it. I can write up a diagram so you don't have to go through the trial and error stuff I did.
Thanks, I just ordered a Parrot Asteroid deck and have a sub and amp from one of my other vehicles. I'll need to purchase the 4 channel amp and door speakers. I was already planning on the Polk for the front (based on Crutchfield). Do you happen to know what model your rear door speakers are? I was looking at the Blaupunkt Blue Magic speakers currently listed for the rears. If you are happy with yours, and they are cheaper, I'm game. I'm a bit of an audiophile as I produce using studio monitors as a hobby, but having something not draining to listen to in my vehicle is all I need. I just want a decent frequency range.
Old Mar 28, 2014 | 12:23 AM
  #32
JohnKimble's Avatar
Don't spend too much on the rear speakers..they are only for fill. The front components are where 90% of your sound is coming from. I'll get you a model number shortly.
Old Mar 28, 2014 | 01:24 PM
  #33
jamestfl's Avatar
Have been looking at this unit. Has just about everything I need- BT, Sirius, Aux jack, CD, what's not to like? thought I'd pass it along...
Alpine - CD - Built-In Bluetooth - In-Dash Deck with Satellite Radio Tuner
Model: CDE-SXM145BT, about $210.
Old Mar 28, 2014 | 01:48 PM
  #34
MarkSF's Avatar
Wanted to mention an interesting problem I had with the Blaupunkt. It wouldn't work - it behaved as if it was muted all the time. I looked at the diagram for the rear connector, and there is a "mute" signal on pin 2, connector A. I cut this wire, and the stereo works great.
So it appears that I permanently had the "mute" on. My steering wheel controls are kind of knackered, so the mute button must have broken so as to be always on.
With the wire cut, my old LR stereo works now, too! Guess I'll keep it as a spare.
Old Mar 28, 2014 | 11:35 PM
  #35
LRD2pdx's Avatar
Adding a single aftermarket sub is always a good idea since factory subs typically can't provide the same level of performance.
I too suffer from the rattling back door but the subs aren't blown, the back door and license plate assembly just need sound proofing badly. I've looked into replacing the factory subs with an couple of aftermarket 6.5" subs and maybe a little bit more power.
Old Mar 30, 2014 | 03:54 PM
  #36
LRD2pdx's Avatar
Here's another great head unit:
http://mobile.jvc.com/product.jsp?mo...thId=54&page=1
$140
I just put one of these in to a customer's Discovery 2 last week. Great deck, great features, even greater price.
I installed this deck along with two pair of Powerbass 6.5" component separates, an Audiobahn 2 channel amp, an Audiobahn monoblock sub amp and two Powerbass 12" subs. Total with labor included $800. The system hits hard, low and clean.
Old Apr 1, 2014 | 11:22 PM
  #37
Echoman's Avatar
I've never heard of Powerbass, but the price is intriguing. I wonder if there are any brick and mortar stores where I could listen to some.
Old Apr 2, 2014 | 04:33 AM
  #38
LRD2pdx's Avatar
Where do you live?
Old Apr 2, 2014 | 11:46 AM
  #39
Quinn519's Avatar
JVC Mobile Entertainment \ Bluetooth CD/USB Receiver - KD-R850BT \ Introduction
$140
Hey LRD2, how easy was it to mount the deck into disco II? since factory stereo a simple 2 top clip/tab that release the deck. Is the JVC you mentioned above the same style (2 top clip/tab) or you need to bolt it onto the car?
Thanks
Old Apr 2, 2014 | 06:48 PM
  #40
LRD2pdx's Avatar
Thanks
I used a kit from Metra and bolted it to the dash in place of the factory deck. The OEM deck is DIN and a half. The Metra kit added a pocket under the JVC. I placed the microphone just over the drivers side seatbelt pillar.
Go back to page 2 of this thread and see the Metra parts picture I posted for 2000 D2.
