Bad luck on an '04
Bad luck on an '04
Taking a 04 Disco apart with 150k on the engine. Supposedly head gasket and engine work done at some point. I call BS.
All 4 corners of the engine were blown out on the water jackets. Timing cover gasket blew out by the water pump. Was taking the engine apart to see if it is savable.
Found this in the oil pan. All aluminum, relatively similar sized chunks. I can't see any visible damage from underneath or anywhere. Any thoughts on where this came from? Oil pump is perfect. Engine can and does run, just doesn't hold coolant. Runs like a turd. There is more in the oil pan, probably 2 cups worth of this debris.
No slipped liners though. Wooopy!
Wow, that's scary. Pop a main cap off and a rod cap and see what the bearing look like. How do the cylinder walls look - cross hatch still there? Any deep scratches? Would have been good to check oil pressure before pulling, but you are past that now. Wash the debris in gasoline, let it dry, lets see what color it is.
wjsj69 (02-28-2019)
20+ LR's so far and not one has ever had any of those issues.
