View Poll Results: DIY or Shop
DIY
68.75%
Shop
31.25%
Voters: 16. You may not vote on this poll
Ball joint, DIY or Shop
Old Mar 23, 2025 | 09:37 AM
DiscoOslo's Avatar
Default Ball joint, DIY or Shop
With spring temperatures, I've discovered a lovely squeal whenever my front driver-side tire turns. The lower ball joint has play, so I am pretty sure I know my culprit. Now my question: Have a shop do it (I've read plenty of the nightmare stories to be a bit worried) or risk it and go DIY. For context, in Norway, there is no loaner program for a ball joint press (that I am aware of), so I would have to buy one. Generally, I avoid the shops to do cost, but I can afford it, if that's the best option. I don't have a lot of free time until May, but I also don't need it. Just looking for opinions. So, DIY or no.
Old Mar 23, 2025 | 10:07 AM
zski128's Avatar
If you don’t have access to or want it invest in the proper tools then a competent shop is your best bet.
Old Mar 23, 2025 | 10:10 AM
DiscoOslo's Avatar
I think my worry is, I will buy a press, then not be able to get them out/in, then have to take it to a shop anyway. I'd be more apt to give it a go if I could loan the tools.
Old Mar 24, 2025 | 08:07 PM
disco_rookie's Avatar
Get/Rent the master kit for ball joint removal, beyond that, it's a walk in the park and documented countless times.
Old Mar 25, 2025 | 10:13 AM
CharminULTRA's Avatar
You can rent the tools from many auto parts stores
Old Mar 25, 2025 | 11:14 AM
mollusc's Avatar
In Norway?
Old Mar 25, 2025 | 11:34 AM
redrover75's Avatar
Buy them on Amazon and return then when you are done?
Old Mar 27, 2025 | 02:15 AM
DiscoOslo's Avatar
Amazon is tricky at best here. Only maybe 1 in 100 products will ship here, often at twice the cost; very little is shipped for free. I found a kit from Germany that is around 140 dollars. That's my best choice at the moment. After thinking it all through and reading the various write-ups on ball joints, I will give it a go.
Old Apr 4, 2025 | 05:56 PM
nashvegas's Avatar
Upper and Lower ball joints on a D2 (if original to the car) are a pain in the ****.
I have a shop do them for me.
I don’t know if those here who are saying “it’s a walk in the parK” -- have you actually done this on a D2? It’s easy on other cars -- but I find these huge D2 ball joints are frozen in there so good they are nearly impossible to remove. Every single time.
Note: If you do them, you will likely 99% of the time, need to very soon replace your axle seal so just do that too. All the banging will cause the seal to go bad.
Old Apr 4, 2025 | 06:22 PM
Yeah, perhaps it's not a walk in the park with a lack of tools. But yeah I hear you, I came from coupe bmws so I wasn't used to truck sized parts on my first d2 ball joint job . But with access to tools and room for everything, it's doable as a first timer.
