Ball joints
Ball joints
How do I properly check for ball joint play on my 03 disco ? I jacked up the front last week and couldn’t feel any play by trying to move tire up and down but I hear some clunking sometimes and still think one or both are going bad
how do you guys properly Check these ball joints
Jack up front of vehicle so wheels are hanging about two inches off the ground, then rest axle housing on jack-stands (this helps eliminate movement of axle housing, while prying with prybar), get a long prybar and someone to either watch ball joint area or pry up for you, place prybar under the tire, then lift upward. You want to watch for independent movement of the ball joint and spindle knuckle, if you are seeing this (ball joint moving upward before whole assembly moves)...ball joint is bad. If the whole assembly moves as one...ball joints are okay. Now, ball joints can become dry inside and cause binding...without showing signs of unusual movement.
Grasping the tire front and back and wiggling would find hub, tie-rod, drag-link or sloppy gearbox issues.
How are the boots on your CV joints, if they are torn...you could have issues there. Bad CV joints will pop while turning if they are bad.
Brian.
Brian.
Brian.
Brian.
thanks brian I will do they. The boots are ok no noise on turns
Do it yourself, Casey Gray (Safari Gard) and I did it on his 04' and while it took us a while, and we ended up breaking one of the new ball joints not paying attention, it was pretty easy.
I think we used MOOG ball joints, his 6" lift rides much better now.
Oh, and most places will rent you the tools, its pretty generic.
