Bank A Oxygen sensor
Old Jun 11, 2009 | 03:49 PM
ghostrider747's Avatar
Default Bank A Oxygen sensor
Where would the bank A one be? Mine needs to be replaced.
Old Jun 11, 2009 | 04:53 PM
I think bank "A" is the drivers side.
Keep in mind that O2's need to be replaced in pairs, so if you replace one front O2 you must also replace the other front O2.
What codes do you have and what is the truck doing?
Old Jun 11, 2009 | 05:09 PM
What is the exact fault code number and how many miles on your truck?
Old Jun 11, 2009 | 08:06 PM
When I get home I will give ya the exact fault codes there were two for the ox sensor both were bank A.One was a low volt and the other was fail to switch lean. I have 118000 on the clock. I have done all the high mile maint to it. Plugs, magna cor wires, Sea foam, Tstat. All my fluids are full synthetic and I burn 93 gas.
Old Jun 11, 2009 | 08:16 PM
lipadj46's Avatar
The rear ones are OK to replace the front ones are fun. All 4 require patience and the ability to shrink your hands, work without seeing what you are doing, and be resistant to burns. But you did the ignition wires you should be used to that. I'm having my own O2 sensor fun now so good luck.
Old Jun 12, 2009 | 08:35 AM
I was wrong there are 3 codes
P0130 (PTH) Oxygen sensor circuit slow response, upstream sensor bank A
P0133(-T-) Oxygen sensor circuit slow response, upstream sensor bank A
P1138 (p--) Oxygen sensor problem with switching lean, sensor(s) for bank A
all were Drive Cycle C
Old Jun 12, 2009 | 08:42 AM
lipadj46's Avatar
Just replace them all, have fun with the front driver's side sensor.
Old Jun 12, 2009 | 09:19 AM
I agree, although you only have codes for one 02 sensor, with your mileage they all need to be replaced.
Check out prices at Rover Connection and Atlantic British.
Old Jun 12, 2009 | 10:28 AM
I am glad I am getting promoted those things are $126 each from Atlantic British
Old Jun 12, 2009 | 10:33 AM
lipadj46's Avatar
That does not sound right. Mine were $70 each from Atlantic British.
