Basket case lives Its alive
Well lets start out by saying i bought a 2000 disco with 83000 miles on it the owner was going to junk it because it overheats I said it probably needs head gaskets he said he did them (he thinks he is a mechanic) i asked if he sent the heads out to be machined and replaced the head bolts he said he looked at them and they looked good and that is a money grab just like the head bolt bull so i bought it off him for $200 and brought it home....it is all there it has nice tires and brakes and a clean body and interior...i have another 2000 that has 198000 miles on it and it needs a trany i bought a donor vehicle that has a rebuilt trany and a rebuilt center locking transfer case that has a rotted rear frame and took it apart well life got busy and i never started it...so i decided to do the head gaskets over on my new one...i took it apart last year and i gota tell you i broke 6 5/8 sockets taking the head bolts off and 2 of them i ended up using a special socket because the heads rounded off,,,i sent the heads out and they needed to be planed got them back last year and i just put them on and i also needed my old power steering pump. he put a new gasket and siliconed it in and the pump didn't work ... all together dosent overheat has air in power steering fluid will try bleeding it i will also check the suction hose for a pinhole or loose clamp it runs shifted good,stops great ice cold A/C dark Green with a tan interior all windows and locks work Yakima roof rack i think im good
2 small problems
The first problem I have is coming up the passenger side back of the engine there is two plastic vacuum lines one of them has a loop that dead ends and the other one I have no clue where it goes any help would be great and the second one is when I woke up this morning I went out I checked all my fluids to make sure everything was up power steering was empty and on the ground I believe it's the hose that comes from the canister up to the pump I'll check that and get back to you
Update
well boil me over BATMAN
I drove the disco twice and on the second trip out for coffee she overheated and there was a lot of pressure in the hoses......so i parked it and was contemplating taking the motor out of my other disco with 198K on it and going through it before putting it in. Then i saw on Craigs list a land rover motor for $100 i called and the owner said he bought it 4 years ago for his wife's disco and never started the project so it sat on the engine stand in the garage he found a rotted fame and junked the disco....I bought the motor and it came with 2 intakes an alternator and $169 worth of new parts from Atlantic British I was in a hurry to get it loaded and beat the traffic ...and when i got back to the shop i noticed it had no power steering pump just an idler pulley ware it would go and the thermostat was different may be this came out of a range rover? how can i tell if it is a 4.0 or 4.6 i will try and post some pix of the 2 throttle bodys,the thermostat and ware the power steering pump should be
Been there and bleed it 4 times and it keeps overheating and develops pressure in the cooling system when i start it i can see air bubbles in the degas bottle i will find my exhaust gas tester to verify it but i can probably say something is cracked did you look at the pix of the replacement motor ? why is there no power steering pump and the thermostat is different???
