Battery acid leaking out of covers
Old Jun 7, 2009 | 07:14 PM
masism's Avatar
Default Battery acid leaking out of covers
So I installed a rebuilt alt and a new battery, took the disco (98) out for the day, came home popped the hood and the battery acid was leaking out of the covers, and was hissing by the negative post.
So I'm going to return the battery but was wondering if it could be the alt to and how I could check that, or hopefully it's just a faulty battery.
Thank you
Old Jun 7, 2009 | 07:54 PM
Repalce the battery, if it happens again then you alt is overcharging.
The only way to check this is to have it tested.
Old Jun 7, 2009 | 08:29 PM
masism's Avatar
Can I check the alt myself or should I take it to a shop. If a shop what shop will have the right equipment to test it.
Old Jun 7, 2009 | 08:53 PM
Take the truck to where you bought the alternator and have it tested, sounds like it is over charging and has killed that battery.
rally1
Feb 22, 2022 06:22 AM
acamato
May 4, 2013 01:41 PM
xoo00oox
Jan 11, 2013 06:23 AM
humroot
Aug 13, 2009 07:38 AM
arrkerr
Dec 14, 2005 10:06 AM
