Bearing-Like Whine
Old 11-20-2007 | 10:19 PM
ajh's Avatar
ajh
Default Bearing-Like Whine
After cleaning the engine bay after filling it with mud I started having a whine that sounds like alternator bearings going. Thinking back though I think I've heard it on and off for the last few months so I guess I shoudn't be surprised. Does anyone know which bearings I need to order if when I pull the belt it does end up being the alternator?
Old 11-21-2007 | 01:07 AM
geotrash's Avatar
Default RE: Bearing-Like Whine
Probably more likely an idler pulley bearing. If it is the alternator, you might as well either have it rebuilt by an alternator shop or replace it with a quality rebuilt one. Usually, alternator shops will match the replacement bearing to the alternator when it's on the bench based on the part numbers on the bearings actually installed.
Dave
Old 11-21-2007 | 05:09 PM
ajh's Avatar
ajh
If it is the alternator I'll want to replace it with a high output unit. Has anyone had luck with a 200A+ alternator they could recommend?
Grlica
05-01-2013 06:13 PM
csb
06-05-2010 08:27 AM
NiveK1970
28
11-24-2009 11:41 PM
Aquaholic
06-15-2007 10:30 AM
2k2wranglerx
03-12-2006 06:44 PM
Quick Reply: Bearing-Like Whine
