Bedliner for wheel flares?
Old Apr 12, 2017 | 08:53 AM
  #21
CollieRover's Avatar
Thanks for all of the discussion, guys. I am going to roller on some bedliner.
Anyone know if bedliner is UV resistant?
Old Apr 12, 2017 | 08:58 AM
  #22
wynhd's Avatar
I had little to no fade with the product used on mine, since it's black, I'll throw on some armour all to shine it up. I believe depending on what product you go with, should state on the packaging, probably doesn't help much if you're looking to know what brand is/ isn't.
Old Apr 12, 2017 | 09:29 AM
  #23
zoltan7's Avatar
Does the plastic need to be scuffed / sanded prior to application or not?
Old Apr 12, 2017 | 07:34 PM
  #24
Zonk872's Avatar
Originally Posted by Manbeer
I'm about to spray my entire D1 in pewter metallic upol raptor bedliner and white bedliner on the roof. TCP global sells their version of the raptor kits which are tintable if anyone feels like getting creative on colors, just a heads up. The raptor works well either rolled on or sprayed. I'll be doing my floors in black as well
I look forward to seeing that color! I am going to paint my roof with the Raptor kit in black. It was done in Plasti Dip for about two years. Looked good but cracked over time in Florida sun. As the rest of the clearcoat on the body deteriorates I am considering spraying it in metallic pewter. Post photos!!!
Old Apr 12, 2017 | 09:34 PM
  #25
Manbeer's Avatar
Will post photos as soon as I get to finish the bodywork, ordering a raptor kit in black to do the interior floors next week as I figured I should practice on the part nobody sees first
Old Apr 13, 2017 | 09:14 AM
  #26
wynhd's Avatar
I believe so, that way you have a clean surface that's free of any product to ensure maximum adhesion.
Old Apr 13, 2017 | 09:26 AM
  #27
Zonk872's Avatar
U-Pol Raptor sells an adhesive spray specifically for a surface like plastic called Grip #4. Search YouTube videos on Raptor and you will find more information. Prep is key! Pattern is dictated by psi and distance of spray pattern. 60- 80 psi with a good compressor not a small pancake compressor. Using protective gear is important too especially a respirator. Stuff is not good for your lungs.
khork
Jan 25, 2014 07:46 PM
nuclearw
Oct 7, 2013 08:11 PM
Zeus
Aug 10, 2010 10:27 AM
abc12xyz
Sep 24, 2009 05:03 AM
bil2mccy
Appearance & Camping Set Ups
Jul 9, 2009 06:50 AM
