Been busy!
Good luck! Just did my bearings, timing kit, oil pump and a heap of seals and o-rings. I'm also hoping to build an engine, buy a used one and send the block/rods and crank to Turner and build up from there. What's your engine build plan? Quite looking forward, never built a v8 before! Nice to have a spare when the non-top hat engine gives up.
Not as bad as I thought - but it did quiet down quite a bit upon cold start. Still have some clacking going on for about 30 sec when cold (maybe a little piston slap), but nice and quiet when up to temp. Oil pressure was always good, and I had replaced the rod and main bearings once already a couple of years ago. Second time torquing the rod bolts down so I’m a little nervous about that - good excuse to start the new build if something happens...
I was able to score a replacement 4.0 block reworked with top hat liners and new cam bearings, 4.6 rods and 4.0 pistons with new pins, a machined 4.6 crank (-10), and a set of rebuilt heads with slightly larger intake valves (the stuff in my signature). I was planning on using my existing Crower cam, lifters, push rods, and rockers that I installed a couple of years ago, but I'm now thinking of going new with all of that too. The "problem" is, that at almost 250K, the original motor runs great - quiet, good compression, and oil pressure. Granted, everything has been replaced or rebuilt on the motor except for pistons/rings, cam bearings, rear main seal, and injectors. I'm just kicking myself in the *** is that I didn't replace the leaking rear main seal when I swapped out the transmission and t-case a few of months ago.
Those can be replaced just by dropping the oil pan and rear main cap.
And, use the Bearmach brand, as they have the full cross oem design, the Allmakes do not.
Probably not the rear main seal leaking, Extinct has a post showing why with the design of the rear cap and a relife/drain in it(and it makes sense when you see it), and that it's the cruciform seals that are leaking.
Sixpack577 (04-15-2020)
