Behind steering wheel - Control spring center spring?
Old Jun 17, 2009 | 08:31 AM
southfloridadiscoII's Avatar
Default Behind steering wheel - Control spring center spring?
Cruise went out, horn went out, old lady crashed into me...land rover fixed the damage but told me that my horn and cruise will not work till this ?? spring was replaced...
600.00 hundred...
does anyone have any experience with this ??spring behind steering wheel..
Old Jun 17, 2009 | 08:51 AM
clock spring?? it think this is the name of the part...i need to look it up....but any help would be appreciated..
Old Jun 17, 2009 | 10:28 AM
GreenDisco2's Avatar
5th Gear
Yes its the clock spring, Is the airbag light on? typically if the bags have deployed the clockspring has to be replaced as it usally melts if the SRS goes off. Be careful buying a used one, as if it wasnt ziptied in the center position when removed and spun while shipping or storage youll be in the same boat after it binds up while you turn and tears the connections or even worse stops you from steering properly. I may have a used one avail. as my friend has a parts truck with low low miles (15k), Ill double check with him if you like. There a simple install, just pull the airbag, then steering wheel and its directly behind the steering wheel and has a multi pin plug on either side and a screw or two.
Old Jun 18, 2009 | 08:45 AM
yes the airbag lite just went on. but bags were never deployed that I know of...let me ask the kids ....ha ha...
sweet let me know if your buddy has one...I am looking to fix this soon...cannot drive in south florida without a horn....
Old Jun 18, 2009 | 08:48 AM
hey could this be related to my accident? old lady backs into my front end but at an angle. hits me right on the corner on the right light.....everything in the front just blows out but no airbag deployment....then this clockspring thing?????insurance will not pay because bags were not deployed...says it was just wear and tear...
jeff spahn
Jul 20, 2018 12:18 PM
schwaggy
Dec 25, 2014 12:19 PM
springer6
Freelander
Oct 29, 2014 09:08 AM
LD420
Feb 25, 2011 06:59 AM
RoverArt
Jan 8, 2011 10:00 AM
