Behold a $26,000 2000 D2
Old Apr 15, 2025 | 06:11 PM
Extinct's Avatar
That looks amazing!
Old Apr 15, 2025 | 07:48 PM
disco96sd's Avatar
sort of but worth it if you plan to drive it in inclement weather
Old Apr 16, 2025 | 02:17 PM
WaltNYC's Avatar
Look at pic 68 and 265 of that BaT auction. They suggest something happened to that truck. Perhaps minor but the bent/crushed panhard rod mount is pretty robust.
Old Apr 17, 2025 | 08:24 AM
disco96sd's Avatar
thanks Walt for your eagle eyes
Old Apr 17, 2025 | 04:06 PM
rikkd's Avatar
I’ve got a low miles D2 w/ an underside that looks like brand new. Those BAT pics aren’t that impressive... at all. Check this out after dry ice blasting. I enjoy looking at it after all the sh--tboxes I’ve had.
I am in awe. Beyond jealous. Every time I clean the underside of my vehicle, a new leak pops up. Or in the case of my wheel well, a leaky axle shaft seal spun about half a quart of oil all over the tire, wheel well, and pretty much everywhere else.
Old Apr 18, 2025 | 02:36 PM
gecko951's Avatar
Maybe one of you has time for this project? 2004 Land Rover Discovery 66k Original Miles First $5000 takes it | Expedition Portal
04 with ~67k miles but originally from PA so there was more rust on the underbody components and frame than I wanted to treat. Also there was rusty bubbling/cracking in the paint on the roof behind the front sunroof and the roof drains were leaking badly so the headliner needs to be replaced and who knows what else might be hiding up there. Speaking of...a mouse made its home in the HVAC system at some point and when you turn on the blower it smells horrible so that needs deep cleaning and the AC doesn't work. Truck was re-painted by some amateur (obvious lack of prep), the rear bumper is broken and missing the turn/reverse lights and there is quite bit of missing exterior plastic trim. The good stuff is that the engine seemed to run well, no overheating or major fluid leaks, brakes work, low range works, suspension seems solid and the interior trim, seats, etc looked great.
Old Apr 19, 2025 | 01:42 PM
longtallsally's Avatar
No rear AC and I can’t see if it has ACE. I don’t care about miles, at that price, little things like the battery cover should be in place.
Originally Posted by disco96sd
Odd feature set. It’s got the wood trim stuff, but nothing else to include even heated seats. That intake looks like it’s seen some corrosion and as mentioned, the track bar being messed up like that.
Neither is an example I’d look at as rear AC, airbags, and if pre-facelift, ACE are hard requirements for me. Man I really screwed up in selling my ‘00…
Old Apr 19, 2025 | 08:21 PM
rikkd's Avatar
My black D2 has wood trim inside, but no front heated seats. The center console wood plate doesn't have the cut outs for it, and I don't feel like drilling into them to add switches. No ACE rear AC or rear air bags either. Someone a while back set it was a special edition type thing but I don't remember which one or if it was true.
fowlerjk04
Apr 19, 2025 01:33 PM
grizzlebar
Aug 31, 2016 08:17 PM
kluber
Apr 21, 2016 07:25 PM
2000 DII
Sep 9, 2011 11:37 PM
timelessride
May 11, 2011 03:59 PM
