Benefits of Transmission fluid and filter change?
It's NOT about "fixing" issues. You change the fluid at 30k intervals and the fluid and filter at 60k intervals. Enough said.
Mine had 84k on it (purchased at 82.5k) when I did the service and it shifted fine. As far as I could tell, it had NEVER been serviced. The fluid smelled bad, was a little dark and the pan had the black sludge and the iron debris on the magnet. Let drain for 3+ hours, changed out the filter and pumped in 8 liters of Mobil 1 ATF. Now it operates just like the ZF transmission in my S Class...beyond smooth, even when manually shifting through the gears.
kpl1228
04-20-2012 06:22 PM
collin Barrows
08-28-2011 07:13 AM
treant985
12-27-2010 02:51 PM
