Benefits of Transmission fluid and filter change?
Old Sep 16, 2014 | 11:48 AM
drowssap's Avatar
you can always put in a D1 pan with a dipstick
Old Sep 16, 2014 | 08:31 PM
Russratt's Avatar
Originally Posted by sdhow
It's NOT about "fixing" issues. You change the fluid at 30k intervals and the fluid and filter at 60k intervals. Enough said.
Mine had 84k on it (purchased at 82.5k) when I did the service and it shifted fine. As far as I could tell, it had NEVER been serviced. The fluid smelled bad, was a little dark and the pan had the black sludge and the iron debris on the magnet. Let drain for 3+ hours, changed out the filter and pumped in 8 liters of Mobil 1 ATF. Now it operates just like the ZF transmission in my S Class...beyond smooth, even when manually shifting through the gears.
See, I'm in the same boat. Bought mine with 83k and I know it's never been done. I did my differentials and t-case last weekend and it was obviously the first service. Nasty oil that was brown/gray. Checked the tranny while I was under there, expecting it to be low but some nasty fluid ran out. I can't wait to service that. A few more things and my truck will be caught up on service.
luckyd77
Jul 2, 2017 09:06 PM
TheGageinator
Oct 31, 2014 03:45 PM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
