Best aftermarket replacement y pipe
Old Jan 9, 2017 | 09:36 AM
Luckyjayb's Avatar
Default Best aftermarket replacement y pipe
looking to replace my y pipe with an aftermarket one. I know most will recommend magnaflow but didn't know if others had used other brands and had any good luck.
Jason
Old Jan 9, 2017 | 09:53 AM
OverRover's Avatar
I can't tell you the best because I just get universal Magnafow cats welded in.... BUT I can tell you what to AVOID>>>> BOSAL!!!!!! That crap doesn't fit and I don't care what vehicle you are using it on. 10 years ago, maybe now BOSAL SUX!
Old Jan 9, 2017 | 03:47 PM
LR03NJ's Avatar
I am thinking of magnaflow too. Seems like well made and stainless steel. I got bad cats already with p0420 all the time and it rattles. Says direct fit.
Old Jan 9, 2017 | 06:46 PM
Luckyjayb's Avatar
I broke down and ordered the magnaflows
Old Jan 9, 2017 | 06:52 PM
Luckyjayb's Avatar
My only concern is that it shows it's has a clamp on the passenger side. I guess I'll have to mount it up for a dry fit then tack weld it and remove it and weld it up. It will get ceramic coated though. It says they have the heat shields but anything I can do to help know down the temps by the u-joint is worth while in my opinion
Paul Grant
Nov 11, 2015 11:48 AM
gribur
Apr 10, 2014 08:29 PM
moorebl
Nov 21, 2013 01:36 PM
dparham
Dec 12, 2012 02:57 PM
ewok
Nov 18, 2010 03:21 PM
