Best coolant?
Old 12-27-2016, 09:24 PM
Luckyjayb's Avatar
Default Best coolant?
Well I'm getting close to having the head gasket job redone and wanted every bodies opinion on the best coolant to use. I was looking at peak global but it's not readily avaliable around me....go figure. I do want a pre mix and will be adding purple ice. I saw some on Toyota red and can get that easily. I'm in central Alabama so the temps vary. Give me some good advice guys and gals.
Old 12-27-2016, 09:42 PM
number9's Avatar
Land Rover Forums - Land Rover Enthusiast Forum - Search Forums
And you'll receive.
Old 12-27-2016, 10:22 PM
Bom2oo2's Avatar
I will tell you which one is worst for this engines, Dexcool,!
The best one is anything else when you replace it every 2 years, (which will cost about half of a full tank of gas by the way),
Old 12-27-2016, 10:53 PM
mln01's Avatar
There is no "best" coolant but there is a worst. Dexcool. I use good ol' Prestone from Walmart.
I question, however, why you want to use a pre-mix. My practice and the practice of many here is to flush the system with distilled water until virtually no anti-freeze color is visible (typically 2 to 3 cycles), then drain by dropping the lower radiator hose and filling with concentrate. That gets you very, very close to a 50-50 mix.
Old 12-28-2016, 08:11 AM
Luckyjayb's Avatar
Well I have flushed the system then actually removed all the coolant back out compliments of the drain plugs n a shop vac. So I have a dry system right now with a new radiator n hose
Old 12-28-2016, 08:52 AM
jastutte's Avatar
use the green stuff with some Water Wetter or the like.
Old 12-28-2016, 01:31 PM
DiscoCam's Avatar
X2
Anything other than dexcool.
Old 12-28-2016, 05:00 PM
AZRover's Avatar
This and a gallon of distilled water......
Old 12-28-2016, 06:21 PM
Big Jim Swade's Avatar
I've still have Dexcool in mine, never had any problems with it. I changed it 4 years ago when I did the thermostat and hoses and again 2 years ago when I did the water pump. I think it works fine if you just change it every few years. I noticed that my new 2016 Can Am Outlander 1000 ATV has orange coolant in it. I figured it was Dexcool also.
Old 12-28-2016, 06:48 PM
Luckyjayb's Avatar
Well I'm not a fan of dexcool
and that is completely out of the question
Quick Reply: Best coolant?
