Best way to torque the crank pulley?
Old 06-18-2018, 05:08 PM
Sixpack577's Avatar
Originally Posted by shanechevelle
Well of course a torque wrench is "perfect" for knowing but dont limit yourself to thinking theres only 1 way to achieve an outcome.
Locking the flywheel with a prybar, using the old serpentine with a prybar, installing the belt and locking other pulleys.
I agree
Old 02-25-2022, 05:59 PM
Buddyp's Avatar
4wd High
Default Crank pulley tool?
Anyone have a link to where I can buy the crank pulley tool or can I offer $ for a copy of the homemade one? I have a wobbly pulley after a rebuild that I think needs re-torqued.
Best,
alex
Old 02-26-2022, 04:55 AM
The Deputy's Avatar
Received 1,278 Likes on 897 Posts
Just pull access plug to flywheel bolts and stick a 18mm socket and extension into an opening in the flywheel, rotate until it binds up, then tighten/loosen crank bolt.
JohnZo (02-26-2022)
Old 02-26-2022, 05:08 AM
frostythor's Avatar
Old 02-26-2022, 12:58 PM
Brandon318's Avatar
This one post should be a sticky haha. It's so effective and so simple, it doesn't make sense to do it any other way.
Old 02-26-2022, 02:47 PM
andino's Avatar
I used a big strap wrench to undo and then torque mine. I did it from below on a lift though so it may be harder if you're working on your back or something.
floydclowser
08-06-2019 02:42 AM
Jeff Blake
05-24-2017 03:05 PM
oilspotLR
12-20-2013 11:14 PM
Pwoens
10-05-2012 01:52 PM
shonuff93
10-07-2009 07:24 AM
Quick Reply: Best way to torque the crank pulley?
