Between exhaust manifold connection to exhaust pipe....
Old Jul 6, 2012 | 02:27 PM
jfall's Avatar
Important!
Chase the thread out with a tap.
That is the only way to assure things will go well.
I snapped off a stud near the end where the nut was.
Then drenched it in WD40.
Used a snapon stud remover that a friend loaned me.
Worked like a champ.
But, I had to tighten, loosen, tighten to get out that stud.
Then chased the thread with a tap which I bought.
Then the stud went in - with the copper colored anti seize.
Best thing is to never touch this stuff if you can avoid it.
Old Jul 6, 2012 | 04:18 PM
twaszak's Avatar
Originally Posted by antichrist
I'd consider just getting a used manifold if you're removing it anyway, then work on the other one at your leisure and sell it or keep as a spare.
That's an excellent idea. I'm calling my junk yard to see if I can find a cheap/acceptable replacement.
In the mean time, I'm trying collect and record as much OBD perf, temp, voltage, fuel, etc etc as I can. If I'm lucky, I'll get enough quality and usable data for a decent before and after comparison.
Cheers,
Thomas
Old Jul 6, 2012 | 04:22 PM
twaszak's Avatar
Originally Posted by jfall
Important!
Good point I hadn't thought of....
Do you remember what size tap to use? (or anyone know?)
Cheers,
Thomas
Old Jul 7, 2012 | 09:53 AM
antichrist's Avatar
M8 x 1.25
Old Jul 7, 2012 | 11:42 AM
FlyingZebra34's Avatar
Another note since we're talking about exhaust pipes... I lost my resonator awhile back. My manifold and Y pipe along with the muffler is sealed and fine now... no CEL but the resonator is gone. Will this effect anything besides noise?
Old Jul 7, 2012 | 02:00 PM
lr2001silver's Avatar
Banned
I dont believe it will affect anything other than not be so quiet anymore. That resonator is a basically. A silencer for the exhaust system.
Old Jul 7, 2012 | 02:36 PM
twaszak's Avatar
I'm not sure I'd know/recognize a resonator if I was looking straight at one.
Which part is / what does it look like / where is the resonator?
Is it before or after the cat? (I'm guessing it's aft)
Tom Rowe: Thx for the tap/thread size..
Cheers,
Thomas
Old Jul 7, 2012 | 03:33 PM
twaszak's Avatar
I just checked google, amazon, and ebay for "m8 x 1.5 taps", "m8 x 1.5 thread", and "m8 x 1.5 chase" and couldn't find anything related to "m8 x 1.5".
I've found a lot of m8x1.25 and m8x1 but not a single m8x1.5.
I've used taps and dies a few times but I'm not very familiar with the different types etc.
What type (tapered, plug, ?) and size (m8x1.25 or m8x1.5?) of tap do I need to chase the threads in the exhaust manifold stud holes?
Where can I get it?
Correct me if I've got this wrong but..."Chasing threads" is basically using a tap with the same thread size as the original threads to clean up threads that might be a little worn or dirty but havn't been stripped? Right?
"Chasing" a thread isn't the same as "repairing" it right?
Thanks much,
Thomas
Old Jul 7, 2012 | 03:50 PM
Bkreutz's Avatar
Where can I get it?
Thanks much,
Thomas
I just went out to the shop and checked the threads on the stud (I have a bag of them from my days at the dealer) they are M8 x 1.25, there are chasing taps that don't cut metal, regular taps have sharper edges. Chasing taps are normally used to clean out threads (either rust or dirt). I use chase threads whenever possible, regular taps can cut more metal out reducing strength.
Old Jul 7, 2012 | 04:38 PM
antichrist's Avatar
Yeah, M8 x 1.25. Sorry, dropped the '2' when I was typing.
I've edited my post to correct.
