BIG PROBLEM PLEASE HELP
Old Jan 23, 2009 | 11:25 PM
lrd2's Avatar
Default RE: BIG PROBLEM PLEASE HELP
am trying to lookfor it roverparts.com but i cant find it
Old Jan 24, 2009 | 12:30 AM
pilsner's Avatar
atlantic british has all of the cooling system parts. when you get it reattached DO NOT FORGET TO BLEED THE AIR OUT OF THE SYSTEM! just search for bleeding cooling system on the forum and you will find plenty of instructions. I spend 3 very frustrating months trouble shooting my rovers cooling system until i found out you hafta bleed the system while on a slope... learn from my mistake.
good luck!
Old Jan 24, 2009 | 01:02 AM
Willie 00D2's Avatar
Is there any white smoke coming out of the exhaust? You might have a bad head gasket, it could be leaking coolant into the cylinder. The compression could also over pressurize the cooling system and pop the hose off.
Willie
Old Jan 24, 2009 | 07:42 AM
llPANCHOll's Avatar
When you replace the thermostat.. replace those crappy clamps..
Get some good screw type clamps..
Old Jan 24, 2009 | 09:14 AM
lrd2's Avatar
no white smoke from the exhaust and yes the clamps are going to be replaced but am not sure if its the thermostat is the problem because i put water in the truck let it cool down and drove it home. the temp. was normal and did not go up. am going to the mechanic now to see what it is.
Old Jan 24, 2009 | 10:17 AM
llPANCHOll's Avatar
Do yourself a Favor..
Replace the thermostat
and MAKE SURE YOU HAVE ENOUGH ANTIFREEZE IN YOUR SYSTEM
Does it ever get below freezing in MIAMI????
Old Jan 24, 2009 | 11:31 AM
lrd2's Avatar
ORIGINAL: llPANCHOll
The coldest it gets is like 40 it got 35 here last week and every body almost died. but yea am going to change it.
Old Jan 24, 2009 | 11:39 AM
lrd2's Avatar
Well i just came back from the mechanic and this is what he told me.
He said all the radiator hoses need to be changed, intake gasket, valve cover gasket, spark plugs, wires, air filter, fuel filter, and drive belt.
now i dont know how much of all of this is true i am going to change the all the radiator hoses and thermostat plus the tune up what do you guys think. i see that the valve covers are leaking oil and the put it on the lift and the bottom is covered with oil i dont know what to do at this point. please help
Old Jan 24, 2009 | 11:52 AM
Disco2Guy's Avatar
Sounds like the 60k service needs to be done. You can search here for it.
Old Jan 24, 2009 | 11:53 AM
lrd2's Avatar
no i have a 2002 d2 with 98kmiles
