Bilstein shock pricing
Old Mar 6, 2010 | 07:45 PM
Baylink's Avatar
Default Bilstein shock pricing
I see Roversnorth has the 4-shock set (RNA6046-7) for $399, and the steering damper for another 90 bucks. Should I expect to beat that by much?
Seems to me I remember someone saying mid-600s on here for a shock set about 3 months ago...
Old Mar 6, 2010 | 08:40 PM
bikingteacher's Avatar
Do you need springs too?
Old Mar 7, 2010 | 09:42 AM
Baylink's Avatar
I don't know. How do I tell?
Old Mar 7, 2010 | 11:21 AM
yloDiscoII's Avatar
Bilstein usually runs a special in April or May where they do "Buy 3, get 1 Free" I got 4 Bilstein 5100's for my Land Cruiser for under $300 with shipping.
Keep an eye out.
Old Mar 8, 2010 | 08:59 AM
XCELLER8's Avatar
check ebay.....I've seen them there not long ago for $295 or so
Old Mar 8, 2010 | 09:24 AM
With your mileage, you need springs and shocks. Consider buying a OME set from Lucky 8, including coils, shocks and a steering stabilizer for $700 ish, you will be better off and have a better shock.
Old Mar 11, 2010 | 09:52 PM
Baylink's Avatar
I see 2 and 3 inch lift sets from them, Mike, but no factory height kits. You got a part number?
Old Mar 12, 2010 | 09:15 AM
You need to realize that your truck has dropped about an inch and a half sense new so to install an OME medium lift will only set you 1/4 to 1/2" taller then new.
Old Mar 12, 2010 | 09:25 AM
Baylink's Avatar
So, you're saying that if I put their '2" lift kit' on a factory new vehicle, I wouldn't get 2" of lift.
That sounds not only counterintuitive, but like false advertising.
I assume that '2" lift' means 'springs 2" longer than new factory springs', and I'd bet everyone else does, too.
Do you have a citation for your assertion here? OME doesn't seem to have their own website, and ARB is similarly unavailing.
Old Mar 12, 2010 | 09:34 AM
Go back and read what I last posted. I said, your truck has dropped from its original height and installing a 2" lift will get you that plus a small amount more back.
If you had a brand new D2 and installed a 2 or 3" lift, then it would be 2 or 3"'s taller the the factory specs.
Not sure why you are making this so hard.
