Black Plastic Windshield Shroud
winshield adhesive is a great product it works great. if your like me ( kinda redneck ) get some it hides well costs just a little and wont win any bueaty contests but its cheep, lexon is a great product too holds stuff on, it all comes down to do u want new or good enough . i am happy with the 20 ft rule if it looks good from 20 ft i am happy
Wow! This is another example of an inferiorly designed Land Rover part. I find it very coincidentally amazing there's another person in the forum with a perfect crack right in the middle of the air intake between the two wipers which looks exactly like mine and I thought it was like that from the factory.
I am trying to mend mine with JB Weld but am not so optimistic the JB Weld will fix it, specially that break in the middle. Mine is split perfectly and in two pieces so I usd JB Weld and mended both pieces with another piece of plastic to reinforce it + JB Weld. We'll see how this goes....
The $260 price from Rovers North is one of the lowest out there but I sent an email out to some junk yard and salvage places to see if they can do a lot better. If unsuccessful, will bite the bullet and buy a new one.
There is still the question: Do you need to remove the hood to install the Air Intake Assembly?
Thanks
Al
Thanks
Al
There is a company called Miami British (miamirovers.com) which sells both OEM and replacement version which is only $199. It's made of fiberglass. What happens is the hood hinges push against the cowl when you raise the hood and over time stresses the part which eventually breaks. That's when you have a tall mechanic or driver raising the hood a little too much. Combined with the heat and years of exposure to the elements it eventually cracks. The part # is JAK000010PMA.
I'm trying to repair mine with JB Weld but it's broken in 4 places (one is the middle where is split into two) and if this doesn't work, then will be spending the $200 to replace it.
Thanks to everyone who replied to this post
Al
Al
Al
Al
Ralph, thanks for the heads up. What year is your Discovery? What type of modifications did you need to make to the fiberglass part? Do you think the fiberglass version is more durable than the plastic one?
It is definitely more durable but will scratch because it is fiberglass so it will show white underneath the paint. The holes for mounting over the wiper motors are not quite centered and the holes that mount to the frame did not align as well. Plus the plastic tabs that mount to the windshield are to thick. I had to cut them off in order to get it to lay flat. Also I had to drill out the mounting hole on one side some in order to get a perfect fit. You will also need to either reuse the finisher seal or purchase a new one.
i jb'd and fiberglassed it like i did the grill. a new part plus shipping to pr makes me want repair stuff id normally replace. also, i'm convinced that this piece will break again.
the truck bed lining is a good solid paint and i used it in lots of spots. it may harden the part up a bit but it won't offer any real additional structural integrity.
this is sort of a step in my roof rail, sunroof, windscreen waterproofing.
JUKE179r (12-19-2016)
