blew oil pump on 04 disco 2 today! Need advice!
oil pump blew apart today while accelerating. Had to drive about a half mile with the oil light on to get to a place to pull over. Take a look at the pics. Would the engine be toast? Or can I throw on another front cover and oil pump and be good to go? Please help! Thanks.
Richard Gallant (05-12-2021)
Main bearings almost never show any wear, cam bearings even less. You can pop a center main bearing cap and look pretty easy, the lower bearings are the only ones that wear. How many miles? I doubt any serious damage was done, sounds like you did not go that far. Assuming it does not look too bad, throw rod bearings in it, new front cover, start it up and check oil pressure.
