Blower motor
Old Apr 28, 2025 | 09:44 AM
bradtheraddad's Avatar
Default Blower motor
Help, 2004 discovery Blower motor stopped working on all settings, replaced motor, resistor, all fuses are good. rear A/C blower still works. there is power to the motor at the plug via a 12v test light. I am stumped! has anyone experienced a similar problem?
Old Apr 28, 2025 | 03:22 PM
Windycity_rover's Avatar
Check the wiring from the plug back. Farther up the line there is another plug. Inspect that the wiring/plug is good. I recently replaced a blower motor and found that plug had began to melt. I believe this is a common issue with that harness. Easy place to start and rule out if all your fuses are good.
Old Apr 28, 2025 | 03:45 PM
I’ll check it out when I get home tonight, thanks for the advice.
Old Apr 28, 2025 | 06:44 PM
Best4x4's Avatar
Does the blower itself run off a 12v battery directly connected to it? Sad to say it but parts quality has really really gone downhill lately.
Old Apr 28, 2025 | 10:55 PM
disco96sd's Avatar
probably the blower switch - they wear out
Black Dynamite
Jul 27, 2021 10:10 AM
Vai2kdna77
May 26, 2021 10:28 PM
chopper789
Feb 11, 2020 10:10 AM
bassinbob
Aug 5, 2013 01:12 PM
Ali
Jan 23, 2008 05:52 PM
