Blower Speed
Old May 4, 2024 | 02:21 PM
  #21
Grum.man's Avatar
Originally Posted by XRAD
IIRC, the full voltage goes into the resistor and the output reduced voltage depends on the AC control fan speed setting. Only FULL speed will ' 'bypass' the resistor for full voltage to the fan motor. Other speeds run through the resistor. So it sounds like you are only 'bypassing' the resistor. I don't remember which side of the motor the resistor is on...ground or Pos.... There are also two relays up high on the motor mounting case. And the brown wire is key. Follow the wiring diagrams for each wire. Someone messed with mine and it took a while to track down the faulty wiring (hidden in black tape)...
yea I did all that. Like I said, no idea why but it works fine now with the later model blower housing and resistor.
Rover_Hokie
Nov 16, 2023 01:35 PM
jeffreysullivan
Nov 16, 2023 01:22 PM
CODisco
Oct 4, 2022 10:46 AM
mr4x4
Oct 22, 2021 11:14 AM
jomandm
Jun 23, 2012 12:25 PM
