Blowing BLACK Soot
Old Apr 19, 2011 | 07:05 AM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Default Blowing BLACK Soot
Recently I had removed/disassembled/cleaned my 1999 LRD2 4.0L GEM intake manifold. My spark plugs are covered with black soot now. My tailpipe end is covered with black soot now. I understand I have a lean/rich problem. However; I'm almost possitive my choke valve is not set right and possibly my idle air control valve. Any suggestions on how to restore this problem back to a smooth idle and no black soot?
Old Apr 19, 2011 | 07:09 AM
LRD2&ME's Avatar
Default Front Differential hub seal.
My 1999 LRD2 has a gear oil leak where the hub meets the differential. The seal looks like it is part of the hub and connects to a large round ball joint. I can not find this seal on Atlantic British. Any suggestions?
Old Apr 19, 2011 | 08:28 AM
AtlanticBritish's Avatar
LR Forum Vendor
Regarding your hub seal...
There seems to be a conflict between the model and part you list here. D2's did not have the large round ball joint that you describe- those were in D1's.
In 1999 Rover offered both D1's and D2's... could it be possible that you have mistaken your D1 for a D2?
The first five digits of your VIN should be able to sort this out.
The following seal should fit the ball joint you describe:
Swivel Ball Seal - ABS - From 1990 for Range Rover Classic, Steering & Suspension Parts
The seal for a D2 would look like this:
Differentials & Other Land Rover Parts | Seal - Pinion - Oil
__________________
Old Apr 19, 2011 | 10:25 AM
LRD2&ME's Avatar
That is the problem with owning a 1999. Strangly enough the VIN thinks I have a D2. I have noticed that some parts are listed either in series 1 or 2 description. But thanks for the reply. The part you suggested looks like the one I need.
Old Apr 19, 2011 | 10:50 AM
'BamaBoy's Avatar
If there's a Gem engine under your hood then you've definitely got a D1, the D2's have the Bosch engine.
Old Apr 19, 2011 | 01:04 PM
dcarr1971's Avatar
FYI...
D1 VINs start SALTJ...
D2 VINs start SALTY...
Old Apr 19, 2011 | 01:14 PM
DarylJ's Avatar
Originally Posted by dcarr1971
FYI...
D1 is SALJ
D2 is SALT
Looks like you added an extra T.
Old Apr 19, 2011 | 01:41 PM
dcarr1971's Avatar
Originally Posted by DarylJ
...Looks like you added an extra T.
...ugh...yep, sorry...good catch...if I could type I'd be dangerous...
Old Apr 19, 2011 | 03:42 PM
LRD2&ME's Avatar
Strange as it may be, my VIN shows it to be a D2. However the body is definitly a D1. And the engine is GEMS. The build date is July 1999.
LRD2&ME
Apr 21, 2011 10:53 AM
ghostrider747
Aug 20, 2009 07:12 PM
2000 DII
Oct 21, 2008 10:19 AM
armyproud
Apr 19, 2008 01:17 PM
wbstyles
Mar 24, 2007 10:29 AM
