Blown fuse F14- Disco wont start- HELP
I have a 2000 Land Rover Discovery II that keeps blowing the fuse F14 in the under dash fuse box.
Most recent history on vehicle- Radiator hose popped off and over heated some. Fixed hose and filled water. Then Disco would not start. Check a number of motor problem possibilities. Started checking fuses. Found F14 fuse blown. Put in new fuse. Disco started up fine. Moved it around, turned off. Went to turn on later- blown fuse. Blows fuse when key is turned to ON position.
Anyone have this problem?? Did a search found nothing.
Any ideas?
Any ideas?
ntavila
01-01-2011 04:17 PM
