Blown fuse F14- Disco wont start- HELP
Old Aug 27, 2009 | 01:01 PM
DiscoLogic's Avatar
Default Blown fuse F14- Disco wont start- HELP
I have a 2000 Land Rover Discovery II that keeps blowing the fuse F14 in the under dash fuse box.
Most recent history on vehicle- Radiator hose popped off and over heated some. Fixed hose and filled water. Then Disco would not start. Check a number of motor problem possibilities. Started checking fuses. Found F14 fuse blown. Put in new fuse. Disco started up fine. Moved it around, turned off. Went to turn on later- blown fuse. Blows fuse when key is turned to ON position.
Anyone have this problem?? Did a search found nothing.
Any ideas?
Old Aug 27, 2009 | 01:06 PM
lipadj46's Avatar
What fuse it that for?
Old Aug 27, 2009 | 01:23 PM
Power fuse for both coils.
He needs to quit replacing the fuse before he does wire harness damage and get it over to his mechanic for a proper diagnostic inspection.
Old Aug 27, 2009 | 01:47 PM
Rover Chris's Avatar
you have a short, Mike is exactly right fuses are to protect wires not components, the fuse blows so you don't start an electrical fire.
Antmen
Feb 17, 2023 05:15 PM
ntavila
Jan 1, 2011 04:17 PM
AK Rover
Apr 1, 2009 12:15 AM
stanigu
Aug 23, 2007 09:39 AM
whiteROVER98
Jul 31, 2007 10:37 AM
