Blown Head Gasket.. again
Old Jun 9, 2019 | 01:29 PM
cobbcj7's Avatar
Question Blown Head Gasket.. again
So it started chirping and now this.. It overheated on me really bad to the point it shut down the motor and black smoke came into the cab of the truck...
Is it worth trying to fix or replace the whole motor??
Old Jun 9, 2019 | 02:01 PM
GCBurke's Avatar
Youll need to do some more diagnostics on the engine to determine that. Pull the heads and have a look .
Old Jun 9, 2019 | 03:10 PM
Landy-04's Avatar
Damn that sucks!
Old Jun 9, 2019 | 03:59 PM
Extinct's Avatar
Before you pull the heads, see if it will start. Listen to it, check the oil pressure. Sometimes when you overheat them so bad they turn off you hurt them bad.
Old Jun 9, 2019 | 05:42 PM
cobbcj7's Avatar
It runs but is very weak.. chirps like hell and is now making a muffled popping sound..
Old Jun 9, 2019 | 05:43 PM
cobbcj7's Avatar
Compression test? What kind of diagnostics? It's only the left side so maybe I can have the head shaved or could the block be warped..
Old Jun 9, 2019 | 07:47 PM
redwhitekat's Avatar
You said head gasket again ?? Did you recently do it ?
Are you monitoring your temps ??
Thst sounds bad
Old Jun 10, 2019 | 05:56 AM
Extinct's Avatar
Check the oil pressure, if it is ok I would start pulling the heads. Very low probability block or heads are warped.
Old Jun 10, 2019 | 07:35 AM
GCBurke's Avatar
A compression test would be a good idea but from the looks of it you need to pull the head. I was referring to see what you got after you pull the head before making a decision on what to do.
Old Jun 10, 2019 | 08:43 AM
NewToTheTwo's Avatar
"It overheated on me really bad to the point it shut down the motor and black smoke came into the cab of the truck"
How exactly does this happen and you not shut it off?
Even the stock gauge should of given a clue well before this point of catastrophe.
