Blown head gasket anyway to get an idea if that is all?
I have a leaky head gasket. I had a hose break and I got hot. Blew it out I guess. Anyway trying to decide on best course of action. I can say that I see no reason to get rid of the vehicle. I still owe some money on it and if I bought something else I will be spending money as well. I am happy with the vehicle. I did not pay a ton for it but with a blown head gasket it is obviously worth next to nothing.
I will like to just get the head gasket fixed. However I understand that sleeves can slip and other issues can also occur. So is there a way to get an idea if the sleeps have slipped or if there is other damage? If I knew that a head gasket was all I need I would just do that. If I had other damage I woudl probably look at a rebuilt engine.
I do not have any misfires and no service engine lights. I do not have any white smoke coming out the tailpipe. My wife says she can smell exhaust but that is the only other symptom. If I top off coolant and bleed air out the temp stays in a good range.
What else could I look for as a sign of other issues?
Robert
Robert
So what I am thinking is taking it into a mechanic in Delta Co that has worked on disco's before. If anyone else knows of mechanics in or around ouray, montrose, delta, etc... let me know.
My hope is that we can proceed like we are doing the head gaskets but he can run tests on the engine to make sure it is solid before we move forward. What all shoudl I ask for as far as tests?
You can have them do a simple pressure test while the engine is still together. If you find that it's leaking externally, that will give them some direction.
From your description it doesn't sound like a cracked block or anything horrible like that. Of course I can't say for sure without doing the diagnosis myself. However, a cracked block will usually cause it to overheat very quickly. Usually within a couple minutes or less when you start driving.
Good luck with it. Hopefully it turns out to be a simple fix.
As I understand it, you'll have to take off the heads to really know whether the damage is to the gasket or if there are larger problems. You'll likely have to get the heads skimmed (they could be warped due to heat) and everything has to be inspected for cracks. Obviously you want to find the root cause of the gasket failure and address that, because if you just change the gaskets and there's something else amiss, that's not going to fix the problem.
Take it to an experienced mechanic if you can afford it.
Thank you for your response. I am for sure taking to a mechanic. Found one in Delta CO that has work on this vehicle before. My main concern is making sure that all steps possible are carried out to insure that if there was a block issue we know then so I can make sure I make the right choices. I intend to keep the vehicle and would like to get this resolved. .
I know for sure it is leaking externally.
As said good idea to get compression test to check for internal leaks.
If found only to be minimal external leak some may recommend using a dose of K-Seal for a temporary repair to seal those. If leaking stops then watch coolant level like a hawk for potential internal leaks, cracked block, liners etc. If no other issues come up a simple HG would probably suffice.
Where are those leaks and how much? Puddles on the ground?
I suppose my main concern is making sure the job is done right. Make sure proper inspections are done while heads are off. The only place I found that can do the job in the near future is estimating around 2k for the head gasket job.
Anyone use the Lucky8 head gasket kit? The mechanic said the gasket kit was 300-ish. If lucky8 is good obviously it is much cheaper.
I'm not sure about any after market parts. I usually get my parts from D.A.P. I think their website is dap-inc.com but I'm not 100% sure. I live close enough, I just go there when I need something.
If you have an external leak from the heads and you can drive for 2 weeks before topping off the coolant. It doesn't sound like a cracked block. There is a kit you can use to check the block itself. If the shop you're going to specializes in Rovers they may have it. It's pretty much just plates to block off the coolant passages into the block. That way you can pressurize the block with the heads off. You apply regulated, compressed air and check around the sleeves for bubbles.
