Blown HG, cause?
Old Nov 12, 2017 | 10:49 AM
Codyt's Avatar
Default Blown HG, cause?
Hi all,
Wifey called today saying the rover was making a new sound. She made it home and I took a look, It’s shooting out air between the head and the block on the passengers side. It’s a 03’ with top hat, crawler cam, arp studs, and grey thermostat. Ultragauge was at 198 when she called 205 when she got home 100 miles later. Just bought this rover back in september so I didn’t do the rebuild. Before I tear into it does anyone have any ideas or theories about what happened?
Old Nov 12, 2017 | 12:22 PM
huggi's Avatar
Hope it's just an exhaust leak
Old Nov 12, 2017 | 12:31 PM
Dave03S's Avatar
Studs not tightened down correctly or came loose?
Old Nov 12, 2017 | 01:35 PM
Sixpack577's Avatar
It tells you on the hood
LAND ROVER
sorry, good luck with it
Old Nov 12, 2017 | 01:41 PM
Richard Gallant's Avatar
205 is not over the top for temps particularly after a 100 miles. So not a a significant overheat issue.
Where is the air shooting out specifically the whole length or 1 spot.
Old Nov 12, 2017 | 05:43 PM
Extinct's Avatar
That’s unusual after a top end job, usually caused by overheating and thermal expansion, yours could be related to improper torque during rebuild
Old Nov 12, 2017 | 06:23 PM
Codyt's Avatar
Its shooting out air in a small spot close to cylinder 6. Compression test was all over the place: #2-180, #4-165, #6-110, #8-190, #1-190, #3-180, #5-170, #7-110. Took all the plugs out and fuel pump relay, cranked 5 times. Only made the air sound when testing #6. So I’m going to start taking her apart and see what’s up. Anyway to tell if these studs were put in right?
Old Nov 12, 2017 | 06:44 PM
Daedrix's Avatar
Banned
Mine did the same thing a while back.
Old Nov 12, 2017 | 07:50 PM
Jwehking's Avatar
Similar. I bought mine with a rebuild just 20k ago. They spent good money including liners. When I got it, unknown to me, it was running 220+ temps, burning oil, and below spec oil pressure. My Machine shop said looks like heads and block face were never milled. My point is you never know, could be bad machinist work or customer foregoes work that should be done. I feel your pain and frustration.
Old Nov 12, 2017 | 08:53 PM
sickws6's Avatar
Ls swap. That's what I'm bout to do when my engine goes.
