Body Lift
Old Aug 6, 2014 | 06:20 AM
OffroadFrance's Avatar
Default Body Lift
Surely just lifting the bodyshell is a pointless exercise without fitting much bigger diameter wheels. The offroad limiting factor has to be the axle/differential height relative to the ground. If one merely lifts the bodyshell the chances of grounding the axles and suspension remain the same unless one increases the height significantly unless it's merely looks some are after. If one increases the rolling diameter by say 2" and axle effective lift is only 1" but is worthwhile. The problem comes in grounding a larger wheel on the fender (wheel) arch. So yes one needs to lift the body but then needs to increase the F&R strut articulation to accommodate. What comes first the chicken or the egg, I suppose one lifts the bodyshell and then increases the rolling wheel diameter but then risks binding up the articulation unless the Panhard and Watts are modified accordingly. It's a quandary. After this many other factors come into play such as drive shaft articulation angles etc.
Surely it would be easier and cheaper to buy a diesel 'monster truck' with all the right kit already fitted?
Just some thoughts on the subject.
When modding your truck in the US do you have to inform your insurance company of such mods as the C of G has also changed considerably and is less stable on tarmac?
Old Aug 6, 2014 | 09:14 AM
swak6287's Avatar
I had driven my Ford Explorer with 3 inch bodylift for many years, offroad and onroad. It allows bigger tires with minimal alteration on the stock suspension system. Do they sell bodylifts for LR1 and LR2?
Old Aug 6, 2014 | 04:12 PM
jwigum's Avatar
Yes, the point of lifting the body is to provide more room for tires(and articulation, to a lesser extent).
You're just spoiling for a fight :P
Old Aug 7, 2014 | 09:55 AM
Not at all jwigum, just curious .............. as always ........... it's the engineer in me
SkyHigh95
Nov 11, 2010 08:29 PM
Gordon Bombay
Apr 28, 2010 11:37 PM
bubblehead5
Jan 31, 2010 05:51 AM
sharp21
Oct 21, 2006 06:54 PM
JRdisco1
Feb 10, 2006 12:34 PM
