Bolt measurements for new drive shafts
Old Jun 16, 2009 | 08:47 PM
Torancis_LR's Avatar
Default Bolt measurements for new drive shafts
Hello, the new Tom Woods just came in today. What are the measurements for the bolts I should get?
Thank you
Old Jun 17, 2009 | 11:58 AM
Measure or use your old ones as a guide.
Old Jun 17, 2009 | 12:51 PM
Disco Alan's Avatar
Not sure about Tom Woods specifics but after I rebuilt mine I reused the original bolts without problem. Not to mention you can't get the 4 bolts off the t-case side without much more unnecessary disassembly. I did get 8 new nuts from the dealer though.
Old Jun 17, 2009 | 01:47 PM
It's all good, went to local hardware store and purchased Grade 8 3/8-24 x 1 1/2 bolts.
Old Jun 17, 2009 | 02:21 PM
oysterhead's Avatar
Slightly off topic, but did you provide measurements to Tom Woods? They asked me to measure from the transfer case to the differential flange. Seems all Disco IIs would be the same (or really close)...
But it would be nice to have measurements from others (to at least confirm I'm measuring the right section).
Thanks.
Old Jun 17, 2009 | 03:09 PM
Thanks.
Yes, TW requires a measurement before ordering. Mine was 24 3/4 but apparently every Disco is different as TW claims. When mine arrived, it was about 23 1/2, it was confirmed by many on this board that the slip joint would compensate for the mis-measurement.
Old Jul 12, 2009 | 12:00 PM
oysterhead's Avatar
why did you decide to replace the bolts?
did TW suggest you replace the bolts?
Old Jul 12, 2009 | 12:18 PM
I purchased the bolts just in case but Thom from the Chicago LR club suggested the old ones were still good when he helped me put it on.
Anyways, I brought the wrong nuts, you need the nyloc and the local store didn't carry grade 8 nyloc nuts.
But yeah, your old ones should work just fine. As long as there not rounded. Did your TW came in yet?
Old Jul 12, 2009 | 12:25 PM
oysterhead's Avatar
no, just about to order it.
i measured 24 7/8".
Old Jul 12, 2009 | 12:31 PM
i measured 24 7/8".
Mine was 24 3/4 give or take. The slip joint would compensate it. I ordered from Will Tillery and got a good price. Try him, he orders directly from TW.
