Bolt Question?? _ size / part#?
Good Afternoon everyone.. after recently acquiring '00 Disco II, I started my preventative maintenance program with a classic oil change to Rotella 15w-40 to hopefully prevent the "flat tappet cam" / ticking at idle.(which is much better after oil change, however still present)...
.. during the oil change, as I was to unbolt the drip pan bolt I noticed a missing bolt about 2.5' / 3' forward roughly along the same line on 'longitude' and to the right a bit. I'm not really sure what to search and the Rave manual unfortunately does not list part#, bolt size, etc..
Here is a pic looking under DISCO II from the DRIVERS' side (left) facing forwards as indicated by the Fresh Napa Gold 1068 Oil Filter
Thanks for any help.
Thanks for the insight.. do you have any pics of the OEM look. Are you saying it is not just a 13mm or something similar?
My oil pan is off right now so cant get you a pic, but I did find an extra screw. Heres one I could find:
http://i27.tinypic.com/2603eyw.jpg
The one I crawled under looked similar to yours (1/2 pics) with "1" line attached to the bolt/hinge/screw.
Mine as you can observed in the 2/2 of pictures has "2" lines.
Do you by chance know the difference b/t the two and if so which size/part #. Thanks
Sorry I dont know. Since you have a 2000, I am guessing that second line is the oil cooler line. Its possible nothing goes in the screw hole in the pan on your year. Maybe someone else can chime in that has a 2002 or older DII.
Thanks again!
