Borla exhaust
RE: Borla exhaust
I got a muffler, tailpipe, and one clamp. the muffler has a lil plate with holes for bolts on either side. from looking under my car I don't see why I couldn't do it myself, so long as I could get the old one off! i just didn't want to get it off and not fit the new one ya kniow then i'd have to drive it somewhere, without anything!
RE: Borla exhaust
I'm just adding this as it may help another. Yes, borla stuff is "bolt on" but I couldn't get the flange loose from the old muffler. So I went ahead and took it to the shop. It was all they could do to get it off with a blow torch!, they only charged me $50. So I figure if you can afford the borla stuff it may be worth it to let someone else do it. Of course this is for all of us who don't own a blow torch.
by the way it sounds AWESOME! I highly recommend
RE: Borla exhaust
like he said if it is a bolt on product, then ok. the getting things off part is easy. a reciprocating saw. don't cut anything you plan to reuse. replace the hangers and all nuts and bolts. cheap easy less rattles. borla is a good product. before you start the disassembly, do a dry fit below the vehicle. jacks and jack stands please. I have seen what happens when a vehicle falls on someone. Not pretty.
make sure things line up as with the original stuff. Once you have everything someone to help is a good thing when you are dealing with any exhaust. While it is a part check the cats out as well. HOpe it helps, gotta love a rover. duboff
