brake booster or master cylinder
Old Aug 4, 2019 | 08:09 PM
Ben Matheson's Avatar
A bad booster will cause a hard pedal not cause it to go to the floor
Old Aug 4, 2019 | 08:28 PM
KernowDiscovery's Avatar
This video describes how the brakes feel when the master cylinder is going out.
https://www.roverparts.com/resources...-discovery-ii/
Old Aug 4, 2019 | 09:02 PM
dwoodskc's Avatar
Originally Posted by Spike555
Master cylinder going bad.
The usual test is to pump up the brakes, press your foot on the brake pedal and hold it, if it goes to the floor it is usually bad. (engine off)
If you can pump them back up but it fades again then it is the master cylinder.
The hissing sound you hear is the vacuum leaking out. The brake booster uses engine vacuum to multiply the pressure you put on the brake pedal.
If the booster goes bad you can pump up the brakes by pumping the pedal repeatedly.
If pumping up the brakes does not work then the master cylinder is bad.
Start the engine, have your wife pump up the brakes while you look/feel/listen for the hiss, it will most likely be coming from the hose that goes from the MC to the engine.
Check for cracks, replace that hose if needed.
If that is all good then replace the MC.
I replaced my master cylinder and bled the brakes. It helped but there is still a very long brake pedal. I’m trying to figure out if it’s the booster. I checked the vacuum tube between booster and engine and it looks fine. It looks new actually.
When I push the brake when the car is off, it is firm.
When I push the brake when the car is on, I hear a hiss(?) near the brake pedal. Bad booster?
I really want to make sure it is the booster before spending $600+ on a new one.
Thanks for your help.
Old Dec 4, 2019 | 08:10 PM
Gary Steel's Avatar
Hi
got a problem with my Disco 2 brakes, she’s a 2000 v8.
pedal a very spongey with some brakes at the end of the travel, if I stamp on the pedal, it goes rock hard and I have no brakes, also noticed a squeaking/ whistle noise when I squeeze the pedal gently, sounds like it’s coming from inside the car.
Old Dec 6, 2019 | 10:43 PM
bosshogt's Avatar
Hi Gary,
A bad booster will not not have the braking power, you normally feel. I swapped a new master cylinder in and it didn't change my pedal feel. Hard pedal with significant reduced braking power is a bad booster. Also my front calipers would not retract and burned up my front rotors. I installed a used booster a few years back and it works fine. Buying new on the booster is not necessary. Get a used one on eBay.
Bosshogt
Andytats
Mar 27, 2022 01:40 AM
romulus prime
Mar 3, 2016 08:40 PM
Mr. Bubs
Oct 4, 2013 07:28 PM
bosshogt
Jun 3, 2013 11:07 AM
drdeadchef
Jun 10, 2012 09:43 AM
