brake caliper spewing fluid
Old Nov 17, 2008 | 10:44 AM
Default RE: brake caliper spewing fluid
You would have to remove the brake line from the caliper or where it somes through the from, anywhere you can unscrew the brake line, and then just cap it with something that will screw over it.
Consider it a "trail" repair. Its not right but it willget you home.
Old Nov 17, 2008 | 10:51 AM
discoxd's Avatar
yeah... should keep me operational till the parts come in... i will try that after work today... thanks spike...
________
Live sex
Old Nov 17, 2008 | 07:49 PM
discoxd's Avatar
update again... i got the short bus operational again after work today... i just pulled the metal section of the rear brake line from the caliper to the distribution block near the rear diff and went to the local parts store and scooped up a small threaded brass plug that would fit where the brake line had been... put some teflon tape on it and plugged it up... no more leak and now i can stop my truck again... just a temp fix until all the parts come in that i ordered today but plenty good enough to get me back and forth to work till i can fix it right...
________
redhead girl Webcams
ArmyRover
Feb 8, 2015 09:04 PM
mln01
Feb 17, 2013 08:11 AM
mburnett
Apr 20, 2007 03:09 PM
i_m_jon
Mar 16, 2007 09:42 PM
