Brake Clamping Force
Old Jan 20, 2017 | 06:55 PM
coors's Avatar
Default Brake Clamping Force
Got a head scratcher. Can't seem to narrow it down.
The brakes have a nice hard bite when the engine is cold (pre-operating temp). Literally, the first couple of pedal presses - the pads bite "controllably" hard.
Once the engine warms up I seem to lose that initial hard bite. Don't get me wrong, the clamping force is adequately safe, but it does not provide that confidence that the first couple pedal presses provide. It makes me wonder why this occurs...
I want to experience a constant consistent hard initial bite.
Could I have Vacuum issue at the booster? Unsure where to look or what to look for.
Pads are new.
Old Jan 20, 2017 | 07:46 PM
Bom2oo2's Avatar
You say pads are new, did brakes start feeling that way with newer pads?
(Are they good quality pads & you are sure it's not the pads loosing bite after they warm up a bit)
Old Jan 20, 2017 | 08:13 PM
Luckyjayb's Avatar
You can check the link from the brake booster to the manifold. It's a single piece unit and plastic. If you take it off, push in on the red connector on the manifold and then pull out while it's pressed in. You can always take it off and tape one end up and fill the tube with water to see if there are any leaks. Just make sure it is dry before u put it back on and depending on when it was last replaced, it's probally brittle like the plastic lines from the coolant tank. If it was going for a while I would say brake fade but you are saying just after leaving the driveway. Makes me think it could be a booster or vacuum issue.
Old Jan 23, 2017 | 12:22 AM
Twix's Avatar
Does your pedal slowly drop to the floor at a light? Could be the master leaking internally
trev0006
Off Topic
May 18, 2010 05:09 AM
