Brake codes and intermittent amigos
I finally invested in a Hawkeye and it is a great device. But I keep getting intermittent amigos and the codes won't clear. The codes seem to be rear height issues and electric shorts or broken wires. First thing I did was check the fuses. Guess what? There are no fuses in the slots. Is my Disco not rera lift equipped? If so why I am getting codes for a malfunction of something I don't have?
Here are the codes I get:
Land rover codes
Brakes
CURRENT
4130 rear left height sensor out of range (short or broken wire)
4131*rear right height sensor out of range (short or broken wire)
4150 rear left (power amp with electrical connection interrupted)
4151*rear right (power amp with electrical connection interrupted)
4152 exhaust (power amp with electrical connection interrupted)
4153 compressor (power amp with electrical connection interrupted)
4136
4137
4167
HISTORICAL
4114 Shuttle valve switch failure electrically supervision
4130
4131
4136 event ON - duration valve LR
4137 event ON - duration valve RR
4150
4151
4152
4153
4167 event ON duration compressor
I should also mention the battery recently died and I just replaced it before I pulled these codes. I think that may explain the shuttle valve switch because I had not gotten it before the failed battery. Most of the current faults were appearing when I checked codes before the battery died.
Any ideas?
Land rover codes
Brakes
CURRENT
4136
4137
4167
HISTORICAL
4130
4131
4150
4151
4152
4153
Any ideas?
do you have springs in the rear or air bags?
do you have a button in the center of your dash that show a picture of a truck with an up & down arrow, next to the gas fill button
when you turn your key on does a red SLS light come on, it would be in the top right side of the speedo
the 4114 Shuttle valve switch failure electrically supervision is what is giving you the amigos
And since you've got a hawkeye, if you've got coils now, use the hawkeye to switch the configuration over to coils instead of SLS (self leveling suspension).
