Brake fuse was blowing, Horn and right indicator not working
Old Dec 29, 2008 | 11:15 AM
johnkbl's Avatar
Default Brake fuse was blowing, Horn and right indicator not working
Hi guys!!
I have a 94 Disco, 3.9, and yesterday and this weekend a friend of mine took it to a ride. Yesterday, he called me and said that the shift lever was stuck in park. The engine could easily turned on and off, but the lever was the problem.
When I got there, checked the fuses and the brake fuse was gone. Replaced it, and the lever started working, but after a minute, I realized that the indicator lighths were not working, and the stop lamps were not working too (when I replaced the fuse, the lights worked).Also, Irealized that the hornwas not working.So... I came to my house, turned off the engine and left it in Neutral position and secured.
Today, I searched for this problem in this forum, and found that a common problem is a short between the third light and the rear defroster. Replaced the fuse, checked the plugs and I really dont remember if there was a short, but I separed them very well. Then, checked the brake lights, working, checked the turn signals, working, checked the horn, not working. Then, Iwent to a ride around the block, and now the horn is still not working, the brake lights are working, and the left indicator is working, but not the right one. I turned on and off the engine several times, and also turned on and off the indicator lighs and emergency lighs, and now the fuse isnot blowing.
When I turn on the right indicator,Ihear the relay, but the light in the dashboard does not turn on. The left one is working fine.
Any idea? is it a common problem?
Thanks all for your help!!
DiscoRover007
Sep 2, 2014 04:49 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
RoverDiscoKiddo
Jan 29, 2012 09:45 PM
lipadj46
Aug 13, 2009 07:47 PM
MalcySP
Jul 12, 2006 05:45 PM
