Brake job, any advice
Old Feb 15, 2011 | 10:01 PM
DiscoBenjamin's Avatar
Default Brake job, any advice
About to do brake pads at the very least, any advice/ recommendations for te job or brand I should use?
Old Feb 15, 2011 | 10:31 PM
jhewitt1111's Avatar
Akebono pads. Best pads I have owned. No dust, no noise, and a lot more stopping power. 300 miles in and counting. It was an easy job.
Old Feb 15, 2011 | 10:35 PM
FightOnUSC79's Avatar
What he said. Also, they work great on the stock LR rotors. Tons of stopping power.
Old Feb 16, 2011 | 06:42 AM
Bundu's Avatar
Banned
x3 on akebono
Old Feb 16, 2011 | 09:19 AM
RedAustinIX's Avatar
Check your rotor thickness - you'd be surprised how fast the rotors wear. Get the cheapo tool at Harbor Freight (I think it's called a micrometer or caliper or something like that). Also, might want to buy a #4 torx bit -- almost impossible to find, and the best way to remove the rotors (otherwise you'll be drilling out the bolt after you strip it with your philips bit).
Ed
Old Feb 16, 2011 | 09:37 AM
Bundu's Avatar
Banned
Get a 1/2" impact driver to remove the screw, it pops out very easily. Get one that you strike with a hammer at home depot. PB blaster is your friend when it comes to removing rotors, soak the hell out of it for an hour or 2 and they come off easily.
Old Feb 16, 2011 | 10:36 AM
Cyberbaker's Avatar
Make sure to fully retract the caliper piston. A C Clamp will work, but you can also get a brake spreader tool for retracting them that works pretty well and is not to expensive.
Old Feb 16, 2011 | 11:12 AM
I used the c clamp. The front has two piston, I just did one at a time very slow.
Old Feb 16, 2011 | 11:19 AM
texmbr's Avatar
Very straight forward job. Plan on doing a complete flush and bleed switching over to sythetic brake fluid. I went with drilled and slotted rotors and akabono's and wow what a difference.
Old Feb 16, 2011 | 02:40 PM
How are your pads with the slotted rotors. I heard the eat them. I stayed with the solid vented rotor.
