Brake Light Switch and Brake Booster
I recently changed my brake booster to resolve an issue with weak brakes. The issue is fixed but I now have another problem...
The brake light switch's plunger will not reach the brake pedal arm anymore. There seems to be a .25" gap between the two. So my brake lights stay on at all times.
Did I install the wrong brake booster? I bought a used one from a recycler on eBay and I'm not sure which year Disco they pulled it out of.
Did you buy a new or used booster? If new where? If it was from Atlantic British then be aware that the list the wrong booster for the D2! I ordered a new booster from AB for my 2004 D2 and it was noticeably smaller (thinner) vs the booster I pulled from my truck. I called them and they sent me a second booster complete with a return label and that was was also thinner. Took a hour long conversation on the phone with them and a 3rd attempt for them to send me the correct replacement brake booster. Ill upload a picture later.
Don't worry I never took offense to your post. I have actually thought of shim as well. I may just do that hah
Weak brakes?
