Brake parts
Hi,
FYI I put new rear rotors (Brembo) & rear Pads (Lockheed) about 3000 miles ago which I purchased for around $140 total from Eurotek APG, have had no squeaking and truck stops on a dime. The fellas were even kind enough to include a few pairs of nitrile gloves and some anti-squeak liquid to coat the pads with first, along with an extremely helpful technical document on how to properly change the pads so that no damage happens to the ABS system. After reading some of the other threads in the Disco forum, the fella that runs the company definitely knows his stuff and won't steer you wrong....
Havent done the fronts yet but will post back on this when I do, you can probably guess where I'll buy 'em
Good luck & enjoy the ride,
Walter
Walter
Atlantic British usually has a couple of quality level available also. Make sure you have a number 4 phillips head and a hand held impact driver and some sound deadening material. Also do a full brake flush when you are done.
TRIARII
Jul 29, 2014 07:36 PM
roverintherocks
Dec 8, 2010 10:36 AM
Jigsaw89
Oct 18, 2010 07:53 PM
